Reload this Page >
Seagull Gee Bee Z
Seagull Gee Bee Z
Old 02-12-2010, 09:42 AM
  #326
[email protected]
Default RE: Seagull Gee Bee Z
here my pics
ID:	1377015   Click image for larger version
ID:	1377016   Click image for larger version
ID:	1377017   Click image for larger version
Old 02-12-2010, 07:39 PM
  #327
rowdog_14
rowdog_14's Avatar
Thanks for the pictures they look good.
Old 02-12-2010, 09:18 PM
  #328
[email protected]
your welcome i really love this plane she handles really nice on the ground and in the air ,my next project is th bh models gilmore red lion 46 .putting a saito 100 in it should be fun
Old 02-12-2010, 11:45 PM
  #329
rowdog_14
rowdog_14's Avatar
I can not wait til I get this gee bee z, I hope it flies as good as my great planes gee bee R2.
Old 02-14-2010, 12:01 PM
  #330
PSJDBF
This plane fly's GREAT ! even with very little pulling it along.
This morning we all had trouble with our engine settings , all had to re-tune etc ( something in the air )
& to make matters worse I was trying a different fuel ,all of which nearly ended in disaster.
Think the setting was to rich & fuel quality not the best ,which resulted in the 170 bogging down ending up with an rpm just above idle
& forcing me to make an emergency landing.
As usual a video of the event.
Steff.
http://www.youtube.com/watch?v=cYPnPv2GAm4
Old 02-14-2010, 03:23 PM
  #331
[email protected]
good job bringing her in .
Old 02-15-2010, 01:01 PM
  #332
tailskid
My Feedback: (34)
tailskid's Avatar
Nice save....I noticed the wing drag on landing....mine does that all the time also!
Old 02-16-2010, 06:52 AM
  #333
PSJDBF
Thanks guys , yeah the wing drag is an issue but I found some plastic insulation tape that is the correct yellow ,(& stretches)
& put some around the wingtips & clear coated it to seal it up ,& it works a treat in protecting the tips.
Will be getting some better fuel in a weeks time which will solve that problem !!.
Steff.
Old 02-16-2010, 10:28 AM
  #334
rowdog_14
rowdog_14's Avatar
They also make plastic tip you can put under the wing that helps with wing drags. When they file down, you just replace them with another. I will find a link and post it
Old 02-19-2010, 01:47 AM
  #335
[email protected]
this bird tends to tip even taxiing just got to keep her striaght till she stops
Old 02-19-2010, 05:58 PM
  #336
tailskid
My Feedback: (34)
tailskid's Avatar
Noticed that also
Old 02-20-2010, 11:14 PM
  #337
[email protected]
first good weekend in month flew the z 3 times 1 bad landing broke cowl mount no biggie  love this bird
Old 02-21-2010, 08:21 AM
  #338
MDHenry
Hello All, Just joined this forum a few days ago and spent that time reviewing all the threads, I was looking for information on how some of the specific details of the Gee Bee were handled and you all have been very helpful. My setup will be Hitec 2.4 with 80 in oz servos, Saito 180 not sure what prop at this time but I tend to use the largest diameter that the engine will swing and make adjustment by opting for different pitch. I am not one for pics but I will try to post some as the project nears completion.
Old 02-21-2010, 01:49 PM
  #339
tailskid
My Feedback: (34)
tailskid's Avatar
I am going to try an 18x6W APC when I fly mine next time....had an interesting 'situation' last weekend - the right side of the fuse was facing the sun and the wing/fuse plastic fairing pulled away from the fuse! Guess my silicon glue didn't do its job correctly.
ID:	1383864   Click image for larger version
ID:	1383865   Click image for larger version
Old 02-23-2010, 06:04 PM
  #340
[email protected]
i uesd canopy glue on all plastic parts never had a problem
Old 02-24-2010, 08:54 PM
  #341
tailskid
My Feedback: (34)
tailskid's Avatar
I sat mind on the flight line with the sun at 90 degrees to the fuselage....re-glued it and we will see what happens when the sun comes out again (rain scheduled for this weekend)
Old 03-20-2010, 07:37 PM
  #342
kahloq
kahloq's Avatar
Wife just ordered one of these for me
Old 04-14-2010, 10:41 AM
  #343
rowdog_14
rowdog_14's Avatar
There has to be a update on somebodies Gee Bee Z. I should have mine on my birthday next month if my money looks right. Post some more updates and videos, mainly videos.
Old 04-15-2010, 02:56 AM
  #344
G3836P
Maidened mine to day.
Turnigy 5065- 380kV
turnigy Sentillion HV 100 amp ESC
8s2s 5000 mAH... two 4s 5000 in series
16/10 turnigy "e" wood prop
Came in at 2300 Watts, which is a little more than this motor is rated for,could use a 16/8,
but I use it sparingly and the motor comes down cool. The plane comes in just under
11 pounds, and flys great. Max effort it will take off in about 15-20 feet, and climb like a rocket, but I usually
like to fly it more scale.
The plane flys great with every thing set as per instructions, but I did take a little down thrust out, and keep the rudder
on the high rate for landing.
Used DuBro 4.5" pnumatic tires on stock main gear, and a Ohio Superstar large plane tail wheel ass. (highly recomended).
Carry power all the way in, and adjust your decent with the throttle, and you can grease it right in, no problems.
No pictures or video at this time, sorry. []
Glenn
Old 04-15-2010, 06:36 PM
  #345
rowdog_14
rowdog_14's Avatar
Great to hear. I love to hear successful flights.
Old 04-17-2010, 12:06 AM
  #346
G3836P
I finaly got a few pictures.
[img][/img]
ID:	1419456   Click image for larger version
ID:	1419457   Click image for larger version
Old 04-18-2010, 10:53 PM
  #347
rowdog_14
rowdog_14's Avatar
NICE!
Old 05-27-2010, 10:02 AM
  #348
rowdog_14
rowdog_14's Avatar
WELLLLL, I have everything but the plane!!!!! I wanted to get it by my birthday but that is not looking good since it is Saturday
Here is my setup
Engine: Supertigre 2300 (1.40)
Receiver: JR R790 Scanselect
Servos: JR DS821 (all surfaces)
Battery: 2500mah nicd
Online it says flying weight is 10.6 -11.5 lbs
I like to keep mine planes at or below the lowest number they advertise. So far I have done that with all my planes.
Well I hope to see more of your Gee Bee's!!!!!!!!!!!!!!!!!!!
Old 05-27-2010, 08:34 PM
  #349
G3836P
You will like it, she is a great flying plane and a croud pleaser at the field.
Be sure to take your time setting it up. Set the CG and controle throws as per the instructions, and you will do great.
Use a long straight approch, and use the throttle to adjust your decent, carry power all the way onto the ground wheel it in and she will almost land herself. But once the tail drops she gets a little squirly, if you are flying off grass no problem, if on asphault you might to put a couple of those nylon wing tip skids on the back half of the of the tip for a while.
Nothing has the presence of a GEE BEE at the field.
Have a ball!
Glenn
Old 05-27-2010, 11:57 PM
  #350
PSJDBF
Put four more flights on mine during the week after a week or so out of action due to a take off incident .
Flying down on the salt lakes south of Perth now & your correct about being a crowd pleaser , you bring her out & a small group starts to gather & talk.
Some photos from the week.
Keep us informed of your progress rowdog you'll love her !!.
Steff.
ID:	1443699   Click image for larger version
ID:	1443700   Click image for larger version
ID:	1443701   Click image for larger version
ID:	1443702   Click image for larger version
ID:	1443703   Click image for larger version
ID:	1443704   Click image for larger version
ID:	1443705   Click image for larger version
ID:	1443707   Click image for larger version
ID:	1443708   Click image for larger version
