Reload this Page >
Seagull Gee Bee Z
Seagull Gee Bee Z
Old 11-17-2009, 03:24 PM
  #176
RevGQ
RevGQ's Avatar
Default RE: Seagull Gee Bee Z
The wheel pants are simply screwed and glued. One half of the pant has plywood glued to it so that it is secured with strap and screws. Its mate is then glued in place.
Old 11-17-2009, 04:30 PM
  #177
PSJDBF
I made up some small blocks of ply and glued them to the inside of the pants so I could use screws to hold them together rather than glueing them, you can bet the time will come when you want to get at those struts or split those pants for some reason !!.
Old 11-17-2009, 05:10 PM
  #178
RevGQ
RevGQ's Avatar
Great idea. I am glad I haven't glue mine together yet.
Old 11-17-2009, 08:43 PM
  #179
PSJDBF
One more thing I did with them that you might want to consider I put some thin Black adhesive foam on the foot of each wheel pant ( where the pant meets the wing surface ) , it fills any gaps between the two ,but more importantly it also gives alittle bit of play/flex between the two so if your leg/strut is bent back alittle on a not so perfect landing the pant will move as well with out cracking /damaging it.
Seems to work well as I have no cracks chipping of paint etc and she has nosed over once on take off at full noise & only suffered a few easily fixed scratches on the cowl & rudder.
Cheers Steff.
Old 11-17-2009, 08:52 PM
  #180
tailskid
My Feedback: (34)
tailskid's Avatar
So you are saying that bolt (which is VERY difficult to loosen) will be the one to 'adjust' the angle?
Old 11-17-2009, 09:04 PM
  #181
R/C Foolish
The reason it is hard to loosen is because there are 2 small set screws. Loosen them up 1st before loosening up the 4mm screw. The gear is not real strong aluminum, mine bent on one particular hard landing. I am thinking about using jb weld to keep the U from moving.
R/C Foolish
Old 11-17-2009, 09:10 PM
  #182
tailskid
My Feedback: (34)
tailskid's Avatar
Not strong? heck they weigh a TON and should be
Are you referring to the three set screws near the 'top' of the strut (that is closest to the wing)?
Old 11-17-2009, 09:20 PM
  #183
R/C Foolish
No, at the base of the fork, there should be 1 or 2 set screws to keep the 4mm screw from turning.
R/C Foolish
Old 11-17-2009, 09:28 PM
  #184
tailskid
My Feedback: (34)
tailskid's Avatar
Might need a microscope to find the second one
ID:	1316161   Click image for larger version
Old 11-19-2009, 04:55 PM
  #185
Peashoooter
Hallo guys!
It is nice to see the same interrest! I am preparing "Z" for next season too and is good to read some advices. I have "Y" by PacAero and it is best plane I ever had. (see video http://www.youtube.com/watch?v=mGW8TIcX5Zg ) So I am curious what Zee can do ...
Have fun!
Ondrej, Czech republic
home site
www.modelranch.cz
Old 11-19-2009, 06:24 PM
  #186
tailskid
My Feedback: (34)
tailskid's Avatar
I think R/C Foolish might have a good idea concerning those landing gears - I can't seem to keep them from twisting and I haven't even installed them yet - suggestions?
Old 11-21-2009, 12:19 PM
  #187
tailskid
My Feedback: (34)
tailskid's Avatar
R/C Foolish, can you describe your method of holding wheel pants on more? I would appreciate it.
Jerry
Old 11-21-2009, 02:23 PM
  #188
tailskid
My Feedback: (34)
tailskid's Avatar
PSJDBF How did you arrange you landing gear wires? I think they are for cosmetic purposes only - I'm thinking of adding some turnbuckles to solve the sag problem.
Jerry
Old 11-22-2009, 08:11 AM
  #189
R/C Foolish
I am not home this weekend, will take pictures next week. I made functional flying wires and reinforced fiberglass and attatched to each side of wheel pants and wing. Then I adjust to keep the pants centered on the wheels. It eliminated any side to side movement of the pants and keeps the wheels from touching. Also use a dremel and make the openings much bigger for your wheels. I am using dubro 4-1/2" instead of the cheap foam wheels that came with the kit.
R/C Foolish
Old 11-22-2009, 02:48 PM
  #190
tailskid
My Feedback: (34)
tailskid's Avatar
The position mine are in will cut into the fiberglass pant sooner or later....probably sooner - going to redo them once I see your pics. Can't believe the 'stock' configuration would last - only three screws holding all that glass - out in the slipstream, then bouncing on the runway - no way!
Old 11-25-2009, 08:33 PM
  #191
wmg706
I glassed brass fuel tube on the inside of the two slots on each wheel pant then ran the cable pulling on each side . I would suggest not flyning the plane until you do that and replace the wheels. I have a 26cc zenoah on mine and when i landed it was like putting on brakes, nosed over . That was the second flight ,first one I listened to someone at the local field and increased elev throws. not a good move! After rebuilding the first 4 inches of the fuselage back to the first former . reglassing one of the wheel pants and cowl I tried it again It flies much better.
Old 11-25-2009, 09:04 PM
  #192
tailskid
My Feedback: (34)
tailskid's Avatar
thanks for the suggestions...question: what wheels did you use as replacements?
Old 11-26-2009, 09:41 AM
  #193
wmg706
I ordered skylite treaded 5" wheels they should arrive tomorrow.Ill let you know how they work out.
Old 11-26-2009, 01:20 PM
  #194
R/C Foolish
I am using the Dubro 4-1/2" lite wheels, nice and solid on landing. Sorry for the delay in my pictures, hopefully I will get them on this weekend.
R/C Foolish
Old 11-27-2009, 12:24 AM
  #195
RevGQ
RevGQ's Avatar
Happy Thanksgiving to all. Place decals on the Z prior to dinner. I am delighted with the MLD-28 engine. I have ran several tanks through her now and she is cranking out the power. The Z is currently weighing in at 11.0 pounds (no wheel pants). I place ignition and ignition battery on the firewall battery plank (ignition underneath and battery on top) and CG is perfect per recommendation.
Pict 1 shows the Tru-turn hub
Pict 3 shows the the small aft-landing gear wire re-attached with steel wire with copper wire and solder on top. I found that the aft- landing gear wire had broke during engine break-in.
Pict 5 shows red wire used to simulate the spark plug wires to cylinders.
Pict 7 show re-enforce aft-landing gear wire on left side.
Pict 8 denotes two charging jacks in front and two switches aft to ignition and receiver batteries.
[img][/img]
ID:	1321368   Click image for larger version
ID:	1321369   Click image for larger version
ID:	1321370   Click image for larger version
ID:	1321371   Click image for larger version
ID:	1321372   Click image for larger version
ID:	1321373   Click image for larger version
ID:	1321374   Click image for larger version
Old 11-28-2009, 06:45 AM
  #196
PSJDBF
Looking good RevGQ !!.
Tailskid I cut a groove into my struts that the rear brace wire fitted into then used a hose clamp to lock it into postion,
the advantage of the hose clamp is you can get them real ! tight ,no movement at all , then for the bracing wires I used one peice & ran it from the inside post
through the pant wrapped it around the hose clamp then out to the other post.I attached the wire to the turnbuckles using the supplied clamp from the kit.
I use thread lock to lock up the turnbuckles , it holds them tight but is easliy undone if tightening is required.
Cheers Steff.
ID:	1321942   Click image for larger version
ID:	1321943   Click image for larger version
ID:	1321944   Click image for larger version
Old 11-28-2009, 08:24 PM
  #197
tailskid
My Feedback: (34)
tailskid's Avatar
PSJDBF Thanks for the pics and the idea...I was going to test fly the bird today but got 'honey-do' list too long to go flying - hopefully tomorrow!
jf
Old 11-29-2009, 10:16 PM
  #198
RevGQ
RevGQ's Avatar
Pretty much done now. Added painted on rivets, as I think it gives the Z its character.
[img][/img][img][/img]
ID:	1323318   Click image for larger version
ID:	1323319   Click image for larger version
ID:	1323320   Click image for larger version
ID:	1323321   Click image for larger version
ID:	1323322   Click image for larger version
ID:	1323323   Click image for larger version
ID:	1323324   Click image for larger version
Old 11-30-2009, 03:17 AM
  #199
PSJDBF
Very nice !!!.Good luck with the maiden.
Steff.
Old 12-12-2009, 05:34 PM
  #200
RevGQ
RevGQ's Avatar
Had a temporary glitch with MLD-28 engine. I would start engine and immediately loose binding to Airtronics RD8000 2.4 GHZ receiver.
After some research here at rcuniverse, I discovered that the plug boot was the primary culprit. Some were suggesting placing a clamp on the boot to keep it stable.
I on the other hand, connected the boot to the plug, then soldered some copper mesh to side of boot in such a way that the mesh would contact the engine head and thereby making a ground.
I then wrapped the boot with a single strand of copper wire, then soldered the wire to the boot the whole way round.
It appears the mods are working great. I ran engine using a Zinger 17x8 prop, tuned the engine adjusting the low-end needle lean until it stopped 4-cycling on the low end. The engined tached at 8200 rpm on the top and 2000 at the bottom. To date, I have run no more than four tanks of fuel. The first three tanks were done with a 30:1 mix of Royal purple. The last was run on a mix of Royal Purple at 90:1.
Here are some picts of the mods to the boot.
[img][/img]
[img][/img]
ID:	1332891   Click image for larger version
ID:	1332892   Click image for larger version
ID:	1332893   Click image for larger version
