Reload this Page >
New Giant Top Flite F6F Hellcat coming soon?
Old 09-30-2019, 04:32 PM
  #351
Chris Nicastro
Chris Nicastro's Avatar
For comparison my latest prop on the DLE 61 is a Mejzlik 24x10 carbon prop. I’d say you could go with a 23in 3 blade and 8-10 pitch. Best advice is to buy a Vario prop and adjust it as needed on the day because as the weather changes you will notice a drop or gain in performance. Plus the prop hub with blades looks and works as good or better than the Solo.
Keep in mind the Mejzlik prop blade is like a Xoar in that it’s not too thin nor scale in profile, just efficient. Other prop makes can be a pretty thin blade which changes the load on the engine but since your interested in a scale look you have to be careful not to go with a wide blade plus the extra blade. The engine load will be too much regardless of the pitch.
I flew a guys H9 Corsair with a one piece 3 blade scale prop and it was totally the wrong prop for the engine. It was under propped and the engine had to rev high in the landing pattern, anyway, bad combo, I call that a scale victim, love the looks but not practical.
Safe to say the old timer standard goes like this;
Add a blade = lose one inch in Pitch, per blade AND one inch in Diameter
so; 24x10 2 blade is roughly equal to a 23x9x3 OR 23x8x3 (in my case, that’s what I’m flying)
If it’s adjustable you can just set it to the right static peak RPM you want and go fly. Just choose the diameter that makes sense for the 61, I believe there’s a 23in dia blade set available.
Old 10-01-2019, 02:40 AM
  #352
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Good advice Chris! Thanks!
Old 10-02-2019, 02:03 AM
  #353
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
did anyone ever find an outlet for the covering? I cant believe this was discontinued!
Old 10-02-2019, 08:40 AM
  #354
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I can find the flat insignia blue but the flat white and flat medium blue are all discontinued. My local hobby shop thinks these were never actually released for sale.
Old 10-02-2019, 08:18 PM
  #355
Chris Nicastro
Which shop is it? I’ll call them and see if I can get a blue roll
Old 10-05-2019, 03:14 AM
  #356
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I bought both rolls that he had in stock but tower Hobbies has it in stock.
Old 11-09-2019, 07:07 PM
  #357
LtMash1A
Any modifications needed to install the Sierra Gear??
Old 11-09-2019, 07:08 PM
  #358
LtMash1A
Did you use baffles in the cowl for Saito 60. If not were your temps OK?
Old 11-10-2019, 12:29 AM
  #359
Chris Nicastro
No I didn’t and the temps are ok. I did add the cowl flaps though.
Old 11-10-2019, 04:46 AM
  #360
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Not sure on the Sierra Gear but the Robarts fit and line up perfectly with no modifications needed. I was impressed that they even have the blind nuts installed! I hope the rails are strong enough. Not much mounting surface. They do have triangle stock running under there but may want to see if there is anything else I can do.
Old 11-10-2019, 06:32 AM
  #361
Propworn
Propworn's Avatar
Originally Posted by wantitbad
I'll go Saturday and take my wife she helps control my spending
That's counter productive!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-15-2019, 09:52 AM
  #362
Bob Paris
My Feedback: (13)
Hay LtMashA1,
I have the Sierra gear in my T.F. F6F and it is a drop in perfect fit. I love Sierra gear...its tough, robust, well built and work well.
Soft Landings Always,
Bobby of Maui
Old 12-01-2019, 12:17 PM
  #363
LtMash1A
The instructions for the lights call or a 4.8V battery. Anyone running them through the receiver with a 6.6 Life battery? Also, can you assign them to a switch? for some reason, I can assign a switch to a port but can't get the lights to turn off and on. Spektrum receiver.
Old 12-01-2019, 12:22 PM
  #364
BarracudaHockey
BarracudaHockey's Avatar
I don't think those lights are switched, I think they only thing they do in the rx is grab power
Old 12-01-2019, 12:31 PM
  #365
LtMash1A
Shouldn't a switch on the transmitter say, Ok, power on, power off?
Old 12-01-2019, 01:14 PM
  #366
Sizemore N
You can use a brushed micro ESC as your switch Cumming off the receiver. Basically what you're doing when you flip the switch on your radio is going from zero throttle on the ESC to Full Throttle which works like a light switch. I have it set up that way in my Hellcat.
Old 12-01-2019, 01:16 PM
  #367
Sizemore N
Also I forgot to mention you can set your Spectrum Radio up to say lights on lights off.
Old 12-01-2019, 02:30 PM
  #368
BarracudaHockey
You can use an 8 dollar RCXL ignition kill.
The servo bus, the positive and negative are always powered on.
The signal line is a timed pulse that varies with the position of the stick or switch associated with it, 1000ms full left, 1500ms for center, 2000ms for full right.
So you either need something to convert that switch like the aforementioned micro ESC, or gas kill switch that translates that signal to off and on, and applies the always on power when switched on and kills it when switched off.
Old 12-01-2019, 03:22 PM
  #369
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I bought this to use with a virtual channel on my Futaba 18SZ.
Hansen Hobbies - Nano Electronic Receiver Switch - V2
I have run the lights on 6 volts with no problem.
Old 12-29-2019, 03:57 PM
  #370
Bryan McLarty
Bryan McLarty's Avatar
It wasn't ever available to purchase. I've checked with my LHS manager. I guess they intended for it to be, but maybe it was just a victim of the Tower Hobbies buyout and acquisition. I'm not holding my breath for it to appear anytime soon either. Booo, hiss...
Old 12-29-2019, 04:16 PM
  #371
CK1
My Feedback: (60)
CK1's Avatar
The matching lt blue/gray covering hasn't been available since the day the F6F was released. I received my F6F early on with some damage and called Tower / Horizon customer service to get the covering . They told me way back then that it would no longer be available . Since then the other flat colors have disappeared from the market as well. It seems they never intended to make the appropriate colors available to the market.
Old 12-29-2019, 04:21 PM
  #372
Bryan McLarty
Originally Posted by Chris Nicastro
Looks like I have an opportunity to set up and fly my friends Hellcat this summer. He just received it this week and is making up his mind on the engine. He might go for the UMS 75cc gas radial, I hope it fits! Otherwise I think he’s going for the Saito 60cc radial.
He said his plane shipped ok, no problems so far with the parts.
Any more development on this UMS 75 radial, Chris? Is it a possibility for fit, performance and weight??
Old 12-30-2019, 03:41 AM
  #373
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks guys. I bought the dark blue to recover my hatch (I did not want any seams after cutting it out) but the blue, despite being the same part number, did not match! For the white (I made new better fitting landing gear covers without holes or that weird cutout for the door and made front doors for the mains), I bought white Monokote and wet sanded it with 400. The sheen looks perfect but again, the shade is off.
Old 12-30-2019, 08:24 AM
  #374
LtMash1A
They should do away with Monokote altogether and use the computer generated composite coverings like TopRC Models.
Old 01-03-2020, 09:57 PM
  #375
Chris Nicastro
‘No he decided to go with the Saito 60cc radial. It’s a nice combo, good performance and great sound. Very good option if you want a radial in this plane.
