Reload this Page >
New Giant Top Flite F6F Hellcat coming soon?
Old 03-14-2020, 07:58 PM
  #426
cgcrc
Originally Posted by R8893
I had problem with the elevator pushrods on mine. The last little bit of the installed guide tubes did not line up with the horn location and the friction was way too much. I had to cut a slot behind the factory location and release the end of the guide tube. Suggest you check that while it is convenient.
Chuck
Hi Chuck:
Thank you for your reply and info.
Good idea to check the guide tubes for smooth operation and alignment. I'll do a rough fit to see how things line up.
Agreed, now's the time to make the adjustments.
Thanks again.
Best regards
Randy
Old 03-15-2020, 03:41 AM
  #427
BarracudaHockey
BarracudaHockey's Avatar
Originally Posted by CK1
I had an issue with the panel bolts coming loose after a flight or two . I thought I hadn't tightened them enough , so I tightened a little more the next time , bad idea , I had a few of the threads strip out in the joiner for the panels . I retapped to next size up and also notched the joiner blade to match the bolt location . The bolt now has to back out a long way before it would disengage the notch . So far they are holding . Just don't turn your gorilla strength loose on the bolts when tightening.
What sort of bolts, what size, and what are they threading into?
Old 03-15-2020, 04:01 AM
  #428
CK1
My Feedback: (60)
CK1's Avatar
I was referring to the wing retaining bolts in the wing joiners.
The threads in the joiner stripped out . The joiner is very soft aluminum.
Old 03-15-2020, 04:10 AM
  #429
Lifer
Lifer's Avatar
There is a thread on the Top Flite Corsair ARF that addresses this issue with clarity. I followed the instructions and the repair worked well. I used threaded brass inserts that I JB welded into the wing and the appropriate sized socket head bolts for the new retainers. No problems since.
Old 03-15-2020, 01:40 PM
  #430
Chris Nicastro
Chris Nicastro's Avatar
That’s right, I posted that fix in the Corsair thread and it should work well for the Hellcat too.
Old 03-15-2020, 02:47 PM
  #431
Lifer
Lifer's Avatar
Yes, I forgot to credit the author!
Old 03-15-2020, 08:06 PM
  #432
cgcrc
Hi Chris:
Would you happen to recall the Corsair thread name and your post number outlining the fix.
Randy
Old 03-15-2020, 10:11 PM
  #433
Chris Nicastro
It’s post #673, I included the Mc Master Carr page info from the inserts I used on my Corsair.
Before anyone goes drilling into the wing please check and understand the construction of the wing. This insert fix works very well in the Corsair but I have not done it on the Hellcat.
Old 03-16-2020, 06:40 AM
  #434
cgcrc
Hi Chris:
Thanks for the post info.
Agreed, just looking at options for now.
Before any mods I'll follow it through a few times to make sure it's a successful mod.
Best regards
Randy
Old 03-27-2020, 09:31 AM
  #435
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Almost done with mine. I thought it might be a good idea to get an extra canopy and wingtip lenses just in case I suffer some hanger rash. Both of these items are already discontinued! Perhaps a Ziroli canopy might fit if I really need one some day. I am disappointed, as you know the covering was never available (except for the dark blue and that does not even match well). I will post some pics of mine when I am done. I did a lot of mods to it.
Old 03-27-2020, 10:53 AM
  #436
CAPT John
My Feedback: (15)
CAPT John's Avatar
I am working on the RTC version and had the same thoughts about ordering a spare canopy. If you determine the Ziroli canopy will work, please let me know.
Thanks!
Old 03-27-2020, 11:46 AM
  #437
Bryan McLarty
Bryan McLarty's Avatar
Great work! If you get a moment, post some pics and describe your mods. I’m just a sting weekend away from finishing my P-47 and then I’ll jump on my Hellcat! Can’t wait!
Old 03-27-2020, 03:36 PM
  #438
Chad Veich
My Feedback: (60)
You would all be better off with the Don Smith canopy since it is the same size as the TF airplane. The Ziroli Hellcat is a much bigger airplane.
https://precisioncutkits.com/product...n-f6f-hellcat/
Old 03-27-2020, 07:15 PM
  #439
CAPT John
My Feedback: (15)
CAPT John's Avatar
Thanks Chad!
Old 03-27-2020, 07:31 PM
  #440
CAPT John
My Feedback: (15)
CAPT John's Avatar
Chuck
Chuck,
My RTC Hellcat has the same pushrod binding issue for both elevators and the rudder. Did you cut a slot behind where the pushrod tub exits the fuselage?
John
Old 03-28-2020, 04:41 AM
  #441
R8893
My Feedback: (20)
Chuck,
John
Yes, that is what I did.
Chuck
Old 03-28-2020, 04:58 AM
  #442
Lifer
Lifer's Avatar
You also have the option of using the next size smaller music wire. It is much stronger than the supplied wire even when thinner. Solder on a threaded coupler at the tail end and you are good to go.
Old 03-28-2020, 09:06 AM
  #443
CAPT John
My Feedback: (15)
CAPT John's Avatar
Good idea. The stock rods are 4-40. I just tried a 2-56 push rod and it still binds. I can see that the outer tube takes a visible bend just prior to the exit hole which is the binding point.
Old 03-28-2020, 09:26 AM
  #444
Lifer
Lifer's Avatar
I think I would ask for a replacement fuselage particularly when the price of the plane is considered.
Old 03-28-2020, 12:27 PM
  #445
Bryan McLarty
I had a similar problem with my TF Giant P-47. I was able to uncover the auxiliary holes and use them. The servos placement came out a little different, but certainly usable.
Left side, elevator only
Right side, elevator upper and aft of the rudder pushrod exit. This allowed for much better function of the stock pushrods without significant binding.
Old 03-28-2020, 12:38 PM
  #446
Bryan McLarty
This photo shows what servos I had to move around to get this configuration to work. The left column bank of servos from top to bottom will be left elev, right elevator, AS3000 stabilizer, throttle, and choke. The right column bank of servos has an AMA name address and phone number plate where that paper is covering it, the tail wheel steering servo, and the rudder servo on the bottom. Not stock arrangement, but clean and works fine.
GOOD LUCK!
Old 03-28-2020, 01:03 PM
  #447
CAPT John
My Feedback: (15)
CAPT John's Avatar
Thanks Bryan.
Old 03-28-2020, 03:01 PM
  #448
RBean
The controls in the Hellcat I purchased used seem to move without binding. I'm glad of that. It is all ready to go. Didn't get to fly it before the "lock down," so don't know when it will be. I installed an Xoar 21-10 three blade prop. I think it looks better, but I'll put the 22-10 two blade back on before the test flight. I opened up the upper cowl flaps. Additional air flow can't hurt.
Old 03-28-2020, 03:39 PM
  #449
CAPT John
My Feedback: (15)
CAPT John's Avatar
Great looking Hellcat! I hope this social distancing need passes soon so we can get back to life under the new normal.
Was the flap joiner tab in your ARF glued into the outboard wing section flap. (They are not pre-installed in the RTC model.)
John
Old 03-29-2020, 03:57 PM
  #450
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Did you guys balance with the gear up or down? The manual only says to balance inverted with an empty fuel tank. The illustration shows the gear up and the drop tank on.
